On 16/02/2018 at 18:38, xxxxxxxx wrote:
How to recover a float type value, with Python ? The code below, allows the input of a value of type float, but I recover a rounded value
import c4d from c4d import gui, documents
class sample(gui.GeDialog) : button_ID = 1001 def CreateLayout(self) : self.GroupBegin(100,c4d.BFH_CENTER,2,0,"Infos"); self.GroupBorder(c4d.BORDER_GROUP_IN) self.GroupBorderSpace(10,5,10,5) self.SetTitle("Sample")
self.AddStaticText(1, c4d.BFH_LEFT, 0, 0, "Name", c4d.BORDER_NONE) self.AddEditText(2,c4d.BFH_LEFT,200,10)
self.AddStaticText(3, c4d.BFH_LEFT, 0, 0, "Weight", c4d.BORDER_NONE) self.AddEditNumber(4, c4d.BFH_LEFT,100,10)
self.GroupEnd() self.AddButton(self.button_ID,c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 100, 15, "Print in console")
def Command(self, id, msg) : if id == self.button_ID: print self.GetString(2) #ok print self.GetFloat(4) #rounded down
self.Close() return True
if __name__=='__main__': dlg = sample() dlg.Open(0,c4d.DLG_TYPE_MODAL_RESIZEABLE,500,300,200) c4d.EventAdd()
On 17/02/2018 at 04:20, xxxxxxxx wrote:
you need to add the following code:
def InitValues(self) : self.SetFloat(4,0.0)
It seems that AddEditNumber use a int as default type
On 17/02/2018 at 09:23, xxxxxxxx wrote:
Thank you Pyr, your solution works perfectly
*********************************************************************** The new code *********************************************************************** import c4d from c4d import gui, documents
def InitValues(self) : ** self.SetFloat(4,0.0)** class sample(gui.GeDialog) : button_ID = 1001 def CreateLayout(self) : self.GroupBegin(100,c4d.BFH_CENTER,2,0,"Infos"); self.GroupBorder(c4d.BORDER_GROUP_IN) self.GroupBorderSpace(10,5,10,5) self.SetTitle("Sample")
self.AddStaticText(3, c4d.BFH_LEFT, 0, 0, "Weight", c4d.BORDER_NONE) self.AddEditNumber(4, c4d.BFH_LEFT,100,10) InitValues(self)
def Command(self, id, msg) : if id == self.button_ID: print self.GetString(2) #ok print self.GetFloat(4) #ok
*********************************************************************** with variant *********************************************************************** import c4d from c4d import gui, documents
self.AddStaticText(3, c4d.BFH_LEFT, 0, 0, "Weight", c4d.BORDER_NONE) self.AddEditNumber(4, c4d.BFH_LEFT,100,10) self.SetFloat(4,0.0)
On 18/02/2018 at 00:31, xxxxxxxx wrote:
i would recommend that you put the initValue inside of your GeDialog class
the advantage is that you didn't need to call the function manually: See GeDialog.InitValue SDK
Called when the dialog is initialized by the GUI.
