On 28/01/2018 at 18:49, xxxxxxxx wrote:
hi all
i want to know how to use python effector data in python generater , can i give clone a attribute like houdini?or just define a global variable?
hope your answer!
On 29/01/2018 at 08:50, xxxxxxxx wrote:
welcome to the Plugin Café forums
Unfortunately I'm not sure where you are heading for. As MoGraph and Effectors is a complex topic, can you please try to be a bit more specific, what you are actually trying to achieve?
On 29/01/2018 at 17:27, xxxxxxxx wrote:
for example, if i get a list in python effector (such as falloff samples or other things ),how can i read it in python generator? thank you!
On 30/01/2018 at 02:05, xxxxxxxx wrote:
I'm terribly sorry, but I still don't get it.
I assume you are talking about a Python Effector in "Deformation Mode: Object" (or similar) instead of the more common MoGraph Effector use-case. But still, why would a object generator want to know about a deformer or an effector? The generator just creates some arbitrary (in the end the polygon cache) and in the following this mesh may be changed/modified/deformed/effected by other objects like for example the Python Effector.
Currently I'm thinking, that you might try to achieve something in a "not so Cinema 4D way" of doing things. I'd really like to help to get you on the right track, but therefore I need to get an idea of the results you want to achieve. If that's a sensitive topic, you don't want to discuss publicly, there's always the option to contact us via mail directly: [email protected].
On 30/01/2018 at 04:04, xxxxxxxx wrote:
Thank you for your patience to answer maybe i should use" Cinema 4D way" to achieve things or just Write a plug-in. thank you very much!
