On 25/01/2018 at 03:12, xxxxxxxx wrote:
Hi everyone,
I'm trying to create a progression bar into my UI, but having difficulties in making it progress and stop when it finishes.
Base on this great example, I manage to make it work, but there is a difference that want to happen.
Instead of having a timer, would like the bar to progress when a function finishes. For example:
|_______| 0%
Def 1: Do Something progressbar += 1
|==|____| 33%
Def 2: Do Something progressbar += 1
|====|__| 66%
Def 3: Do Something progressbar += 1
|======| 100% Done!
If I create a function that adds the progress, unfortunately when it gets to end it does not display the message, has it seems is not running the Message Built-In Function.
def Message(self, msg, result) : if msg.GetId() == c4d.BFM_TIMER_MESSAGE: if self.progress==10: self.StopProgress() self.Close() return True return gui.GeDialog.Message(self, msg, result)
I'm trying to understand the logic for this and been struggling for a bit. Apologies if this sounds confusion and will try my best to add any information needed.
Thank you in advance!
Andre
On 26/01/2018 at 03:40, xxxxxxxx wrote:
As I understand, you don't use a timer in your dialog so BFM_TIMER_MESSAGE is never send. For each of the 3 progress step send the update message to the progress bar with:
self.progress += 1.0/3.0 progressMsg[c4d.BFM_STATUSBAR_PROGRESS] = self.progress
Then after the last step with a progress of 1.0 the progress dialog can be closed.
Note there's an issue in the code I posted in the thread you linked. The dialog is closed after 11 timer calls while this should be done after 10. self.progress==10 is checked in BFM_TIMER_MESSAGE after the 11th timer call. To fix this the code in Message() for BFM_TIMER_MESSAGE should be moved at the end of Timer(). In fact Timer() is called for each BFM_TIMER_MESSAGE so there's no reason to use both in a dialog. Moreover this has lead to the previous issue.
On 30/01/2018 at 01:23, xxxxxxxx wrote:
Hi Yannick,
Apologies for the slow reply! Just had a chance of seeing this today.
Thank you very much for your time and help! Will have a look and come back to you. But it does make sense.
Thank you again!
On 30/01/2018 at 03:25, xxxxxxxx wrote:
Just to let everyone know that it works like a charm!
You're a star Yannick!
