On 08/01/2018 at 07:36, xxxxxxxx wrote:
I have an Object Generator plugin that has an only one button. I want to perform some operations when pressing it. For example, create a sphere and insert it under Object Generator plugin...
Here is how my code looks like, but it's not working...
import c4d from c4d import plugins, utils import os TESTPLUGIN_ID = 1040447 TESTPLUGIN_VALUE = 1000 class Testplugin(c4d.plugins.ObjectData) : def Message(self, node, type, data) : if type == c4d.MSG_DESCRIPTION_COMMAND: if data["id"][0].id == TESTPLUGIN_VALUE: sphere = c4d.BaseObject(c4d.Osphere) sphere.InsertUnder(node) return True if __name__ == "__main__": bmp = c4d.bitmaps.BaseBitmap() dir, file = os.path.split(__file__) fn = os.path.join(dir, "res", "icon.tif") bmp.InitWith(fn) result = plugins.RegisterObjectPlugin( id = TESTPLUGIN_ID, str = "Test Plugin", g = Testplugin, description = "Otestplugin", info = c4d.OBJECT_GENERATOR, icon = bmp)
On 08/01/2018 at 10:12, xxxxxxxx wrote:
Figured it out...
1. import c4d 2. from c4d import plugins, utils 3. import os 4. 5. TESTPLUGIN_ID = 1040447 6. TESTPLUGIN_VALUE = 1000 7. 8. class Testplugin(c4d.plugins.ObjectData) : 9. 10. def Message(self, node, type, data) : 11. if type == c4d.MSG_DESCRIPTION_COMMAND: 12. if data["id"][0].id == TESTPLUGIN_VALUE: 13. sphere = c4d.BaseObject(c4d.Osphere) 14. sphere.InsertUnder(node) 15. return True 16. 17. if __name__ == "__main__": 18. bmp = c4d.bitmaps.BaseBitmap() 19. dir, file = os.path.split(__file__) 20. fn = os.path.join(dir, "res", "icon.tif") 21. bmp.InitWith(fn) 22. result = plugins.RegisterObjectPlugin( 23. id = TESTPLUGIN_ID, 24. str = "Test Plugin", 25. g = Testplugin, 26. description = 27. "Otestplugin", 28. info = c4d.OBJECT_GENERATOR, 29. icon = bmp)
On 08/01/2018 at 10:13, xxxxxxxx wrote:
I had to convert tabs into spaces
On 09/01/2018 at 02:51, xxxxxxxx wrote:
Hi Merk,
Python pays a lot of attention to indentation and is never suggested to mix up spaces and tabs. Beware for the next time
Best, Riccardo
