On 06/01/2018 at 18:59, xxxxxxxx wrote:
Hello Plugincafe!
With this python generator, I want to remove short segments of a spline. In line 17 I'm exploding spline into segments and in line 30 I'm trying to delete short segments but seems like I'm doing something wrong.
minLength = op[c4d.ID_USERDATA,1] #User defined Minimum lenght for i in xrange(pcount) : pointA = spline.GetPoint(spline.GetPointCount()-i-1) pointB = spline.GetPoint(spline.GetPointCount()-i-2) direction = (pointB - pointA) distance = direction.GetLength() if distance == 0: continue elif distance < minLength: sel.Select(spline.GetPointCount()-i-1) sel.Select(spline.GetPointCount()-i-2) res = utils.SendModelingCommand(command = c4d.MCOMMAND_DELETE,list=[spline],mode=c4d.MODELINGCOMMANDMODE_POINTSELECTION,doc=doc) sel.DeselectAll()
On 07/01/2018 at 05:44, xxxxxxxx wrote:
I found a solution... this is a bit brute force way, but at least it works...
import c4d #Welcome to the world of Python def main() : child = op.GetDown() if not child: return clone = child.GetClone() child.Touch() PolyFX = c4d.BaseObject(1019222) PolyFX[c4d.MGPOLYFX_MODE] = 1 PolyFX[c4d.ID_MG_TRANSFORM_SCALE] = c4d.Vector(0.99) PolyFX.InsertUnder(clone) res = c4d.utils.SendModelingCommand(command = c4d.MCOMMAND_CURRENTSTATETOOBJECT, list = [clone], mode = c4d.MODELINGCOMMANDMODE_ALL, doc = op.GetDocument(), ) if res[0] is not None: poly = res[0] else: return None sel = poly.GetPointS() pcount = poly.GetPointCount() sel.SelectAll(pcount-1) res = c4d.utils.SendModelingCommand(command = c4d.MCOMMAND_EXPLODESEGMENTS, list = [poly], mode = c4d.MODELINGCOMMANDMODE_POINTSELECTION, doc = op.GetDocument() ) length = c4d.utils.SplineLengthData() for i in poly.GetChildren() : length.Init(i) dist = length.GetLength() if dist < op[c4d.ID_USERDATA,1]: i.Remove() length.Free() return poly
On 07/01/2018 at 06:33, xxxxxxxx wrote:
Worth mentioning that this technique is a bit slow...
On 07/01/2018 at 09:26, xxxxxxxx wrote:
I figured it out...
doc = op.GetDocument() sel = spline.GetPointS() minLength = op[c4d.ID_USERDATA,1] #User defined Minimum lenght n = 0 for i in xrange(spline.GetPointCount()-1) : pointA = spline.GetPoint(n) n+=1 pointB = spline.GetPoint(n) direction = (pointB - pointA) distance = direction.GetLength() if distance == 0: n+=1 elif distance < minLength: sel.Select(n) res = utils.SendModelingCommand(command = c4d.MCOMMAND_DISCONNECT,list=[spline],mode=c4d.MODELINGCOMMANDMODE_POINTSELECTION,doc=doc) res = utils.SendModelingCommand(command = c4d.MCOMMAND_DELETE,list=[spline],mode=c4d.MODELINGCOMMANDMODE_POINTSELECTION,doc=doc) n+=1 sel.DeselectAll()
On 08/01/2018 at 02:08, xxxxxxxx wrote:
Hi Merk, although it seems out you've already find your own way, I wonder looking at your second post, if an ObjectData Python plugin would fit better with the intent of the code since I see you handling object's child as much as normally happens with an ObjectData. Is my guess wrong?
Best, Riccardo
On 08/01/2018 at 02:54, xxxxxxxx wrote:
In object generator plugins, I'm using GetAndCheckHierarchyClone. In the second example, python generator is used...
