Remove NGons
On 26/12/2017 at 06:19, xxxxxxxx wrote:
I tried to remove Ngons of a polygonal object but this script has no influence over the geometry.
1. import c4d 2. 3. def main() : 4. 5. op.GetPolygonS().SelectAll(op.GetPolygonCount()) 6. res = c4d.utils.SendModelingCommand(command = c4d.ID_NGON_REMOVE_MENU, 7. list = [op], 8. mode = c4d.MODELINGCOMMANDMODE_POLYGONSELECTION, 9. doc = doc) 10. c4d.EventAdd() 11. if __name__=='__main__': 12. main()
Sometimes I'm getting this error: A problem with this project has been detected: Object "Plane" - Polygon selection out of bounds. Please save and contact MAXON Support with a description of the last used commands, actions or plugins.
On 26/12/2017 at 09:33, xxxxxxxx wrote:
I never used this command but some SendModelingCommand return the object modified. Then you need to insert it into your document.
Anyway print res.
On 26/12/2017 at 10:00, xxxxxxxx wrote:
1. import c4d 2. 3. def main() : 4. 5. if op: 6. res = c4d.utils.SendModelingCommand(command = c4d.ID_NGON_REMOVE_MENU, 7. list = [op], 8. mode = c4d.MODELINGCOMMANDMODE_POLYGONSELECTION, 9. doc = op.GetDocument()) 10. **print res** 11. c4d.EventAdd() 12. if __name__=='__main__': 13. main()
for some reason, this code returns False
I have selected polygonal object that has NGon lines.
On 26/12/2017 at 10:13, xxxxxxxx wrote:
ID_NGON_REMOVE_MENU is a menu command ID, not a modeling command ID so it must be used with CallCommand() instead of SendModelingCommand().
Also, the command processes the selected Ngons. The code can be converted to:import c4d def main() : sel = c4d.BaseSelect() op.GetSelectedNgons(sel) sel.SelectAll(op.GetNgonCount()) c4d.CallCommand(c4d.ID_NGON_REMOVE_MENU) c4d.EventAdd() if __name__=='__main__': main()
On 26/12/2017 at 10:24, xxxxxxxx wrote:
is it possible to use CallCommand() in python generator or in generator plugins? or it can be used only as a script?
On 26/12/2017 at 10:30, xxxxxxxx wrote:
CallCommand() is only allowed from the main thread so it's forbidden from generators. Sorry.
