On 26/02/2003 at 07:53, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.012 Platform: Language(s) : C.O.F.F.E.E ;
--------- Simple question...lost in sdk... I am trying to add an icon and a logo picture to my dialog box...but cant figure out how... I know you need to use a resource somehow... thanks pixolinx->Dev newbie();
On 26/02/2003 at 11:15, xxxxxxxx wrote:
Let's try this again with IE crashing!!!! Here's how to add an Icon to the Plugin's menu item:
Bool PluginStart() { WhateverData* whateverdata = NULL; // initialize global resource object if (!resource.Init()) return FALSE; // create new instance of WhateverData class if ((whateverdata = gNew WhateverData) == NULL) { GePrint(GeLoadString(IDS_PLUGIN_NAME) + ": "+GeLoadString(IDS_ERR_CONSTR)); return FALSE; } // register hook, ADD MENU ICON, and return return (RegisterCommandPlugin(PLUGIN_ID, GeLoadString(IDS_PLUGIN_NAME), 0, "pluginicon.tif", GeLoadString(IDS_PLUGIN_DESCR), whateverdata)); }
And here's how to add Icons to your dialogs:
Bool ErrorDialog::CreateLayout() { BitmapButtonCustomGui* erroricon; SetTitle(GeLoadString(ERROR_DIALOG_TITLE)); GroupBegin(5000, BFH_CENTER, 2, 2, NULL, 0); { // some room for the icon GroupBorderSpace( 8, 8, 8, 8 ); { BaseContainer settings; settings.SetBool(BITMAPBUTTON_BUTTON,TRUE); erroricon = (BitmapButtonCustomGui* )AddCustomGui(4000,CUSTOMGUI_BITMAPBUTTON,String(),BFH_FIT,0,0,settings); } if (erroricon) erroricon->SetImage(GeGetPluginPath() + Filename("res") + Filename("erroricon.tif")); ... GroupEnd(); }
HTH, Robert
On 27/02/2003 at 06:07, xxxxxxxx wrote:
The guy needs coffee and not C++ The bitmapbutton class is not available in COFFEE. pixolinx, check the examples that are available for COFFEE (you can download them here in the plugincafe afaik). U will have to use a UserArea to show an icon or picture in your dialog. Please also try to search the old forum for UserArea help.
On 27/02/2003 at 09:09, xxxxxxxx wrote:
Didn't even notice. Seems I needed some "Coffee" too. ;0) Robert
On 28/02/2003 at 04:23, xxxxxxxx wrote:
Thanks guys... pixolinx
