On 05/12/2017 at 07:42, xxxxxxxx wrote:
Cinema 4D Version: R18
Platform: Windows ;
Language(s) : PYTHON ;
Hi, I would like to know if it is possible to define a specific color for the wireframe for separate object.
The main idea and goal is to get the same result as put objects in layer color mode and be in Lines mode in the viewport. But if you go on Gouraud Shading, the object itself have the color layer.
What I want to achieve is
first : Change Wireframe Color without affecting the shading in Gouraud Shading (for ex: Grey Shading for all object but different colors wireframes )
2nd : Create object with random wire color when creating new object.
3thrd : Select SameWireColorObject so if you get multiple objects with same wirecolor ,you can select them in one click.
I don't know if it is possible, and how hard it is to achieved.
Thank you for your help,
Best Regards
