[SOLVED]Turn between SplineData and BaseContainer?
  • On 29/11/2017 at 04:13, xxxxxxxx wrote:
    [Original Topic] Convert between SplineData and base container?
    [Original Post]
    Hello, again!
    In a previous Topic, I learn how to create a default spline user data.
    But there comes some other problems.
    <1> If I want to use c4d.SplineData to set some value first, then turn it into a base container for adding it to user data,
    <2> or use c4d.SplineData to change some value in a predefined "SplineData" base container,
    how can I do?
    Thanks again~
  • On 29/11/2017 at 05:41, xxxxxxxx wrote:
    def main() :
        obj = doc.GetActiveObject()
        if not obj: return
        # Create Spline Data
        bc = c4d.GetCustomDatatypeDefault(c4d.CUSTOMDATATYPE_SPLINE)
        bc[c4d.DESC_NAME] = "Spline"
        splineID = obj.AddUserData(bc)
        # Assign default vaue
        spline = c4d.SplineData()
        spline.SetKnot(1,c4d.Vector(1,1,0))
        obj[splineID] = spline
    if __name__=='__main__':
    Basicly SplineData do not get a Basecontainer but it's the host objet that have one. And you copy or set this basecontainer that link to a SplineData.
  • On 29/11/2017 at 08:53, xxxxxxxx wrote:
    Thank you for your patience and detail answer!
    I learn a lot!
    Thank you again!
