Serial.cpp
    On 21/02/2003 at 07:25, xxxxxxxx wrote:
    Cinema 4D Version:   8.012
    Platform:   Windows  ;
    Does anybody know how to use that project example? I made it run, but to be honest I don´t understand what the routine checks for. What does the user have to input in the dialog to make the example serial checking succeed? (something with TEST- but then?? Don´t get it)
    Any help appreciated. Rob? :)
    Best
    Samir
    On 22/02/2003 at 23:51, xxxxxxxx wrote:
    If the example is so confusing it's probably easier to write your own. There are no unique ideas in that code. But I think that the number must begin with "TEST" and a number.
    You only have to note the ReadPluginInfo()/WritePluginInfo() calls to store encrypted information. The rest is just dialog management, afaict.
    (C'mon, hackers have long been able to circumvent and reverse engineer serial schemes with a debugger only. And here you have the whole source code at your disposal... ;-)
    On 23/02/2003 at 04:05, xxxxxxxx wrote:
    yes, I have already. :) Thanks anyway
    On 16/05/2004 at 18:54, xxxxxxxx wrote:
    Howdy,
    What about the line:
    #define MYPLUGIN_ID    9999999 // CHANGE THIS !!!!
    Is this supposed to be a new ID from Plugin Cafe or the current ID of the plugin to be registered.
    What if there are several IDs in a plugin suite?
    Adios,
    Cactus Dan
    On 17/05/2004 at 06:25, xxxxxxxx wrote:
    That's a new unique ID, for the serial number part of the plugin.
    On 17/05/2004 at 14:18, xxxxxxxx wrote:
    Howdy,
    Thanks, Mikael.
    Adios,
    Cactus Dan
