Get all shaders use in a material
  • On 24/10/2017 at 00:47, xxxxxxxx wrote:
    Cinema 4D Version:   R18
    Platform:   Windows  ;
    Hello.
    I need to know if there is any Color Shader in a Material parameter.
    To do that I parse the inserted shaders in the material via GetFirstShader and GetNext.
    I suppose I also have to parse the retrieved shaders recursively.
    Is this the correct way to get all the shaders used in a material ?
    Thank you for your time !
  • On 24/10/2017 at 01:21, xxxxxxxx wrote:
    Hi Peterakos, your assumption is correct.
    Actually traversing the shader tree almost behaves to the same "rules" of traversing the scene tree.
    Best, Riccardo
  • On 26/10/2017 at 05:17, xxxxxxxx wrote:
    Hi Peterakos,
    in general Riccardo's answer is correct. But we figured out, one will be missing a few corner cases with this approach.
    There are some shaders which support sub-shaders, but for historic and/or architectural reasons these do not insert their sub-shaders into the shader tree of a material.
    For these you will need to do a separate traversal starting with the shader(s) from their parameters.
    Here are the shaders, their IDs and shader parameters:
    Colorizer (ID: Xcolorizer from xslacolorizer.h, parameter SLA_COLORIZER_TEXTURE)
    MoGraph MultiShader (ID: 1019397, parameters MGMULTISHADER_LAYER_LINK (first shader, next ones follow by +1) and MGMULTISHADER_LAYERCOUNT (number of shaders) from xmg_multi.h)
    Sketch&Toon Art Shader (ID: 1012161, parameters ARTSHADER_TEXTURE, ARTSHADER_SHADOW_TEXTURE and ARTSHADER_BACKFACE_TEXTURE from xartshader.h)
    Sketch&Toon Hatch Shader (ID: 1012166, parameter HATCHINGSHADER_TEXTURE from xhatchingshader.h)
    Sketch&Toon Spots Shader (ID: 1012160, parameter SPOTSHADER_GAP_TEXTURE from xspotshader.h)
    You might consider to browse the descriptions of shaders for shader links to end up with a generic implementation. But then be extra careful you don't end in an endless loop, with shaders which do insert sub-shaders intro the tree (e.g. layer shader).
