Dirty when visibility or enabled changes
  • On 20/10/2017 at 02:51, xxxxxxxx wrote:
    I have an object plugin and I want to detect when the Visibility (Editor or Rendered) or Enabled of the child  object changes?
    I am checking IsDirty in GetVirtualObjects(), but the child is not dirty when I change the Visibility or Enabled.
    dirty = child.IsDirty(c4d.DIRTY_MATRIX | c4d.DIRTY_DATA | c4d.DIRTY_CACHE)
  • On 23/10/2017 at 22:14, xxxxxxxx wrote:
    Hi Pim, thanks for writing us.
    From a brief test I can't reproduce the issue you mentioned since the code below properly regenerates "new" geometry every time render/editor visibility is changed or the object is turned on/off.
      def GetVirtualObjects(self, op, hh) :
          if op is None or hh is None:
              return None
          child = op.GetDown()
          if not child:
              return None
          childDirty = child.IsDirty(c4d.DIRTY_MATRIX | c4d.DIRTY_DATA | c4d.DIRTY_CACHE)
          child.Touch()
          cache = op.GetCache()
          if not childDirty and cache is not None:
              print "cache"
              return cache
              print "regenerated"
          sphere = c4d.BaseObject(c4d.Osphere)
          sphere.SetMl(child.GetMl())
          return sphere
    Maybe I didn't properly get your point?
    Best, Riccardo
  • On 31/10/2017 at 00:52, xxxxxxxx wrote:
    Sorry, together with the answers in the other post, the issue is now solved and I guess you are correct.
    I took the wrong approach.
    -Pim
