On 15/10/2017 at 08:36, xxxxxxxx wrote:
Hi all!
Been trying to get my script ready that simple makes a vertex map tag based on a polygon selection. Inside c4d you do this with the Set vertex map command. But inside python it works a little different I think??
Setting the vertex map is with: vertexmaptag.SetAllHighlevelData(selection tag values here)
But how do I set the selection tag to be the value to make to weight tag? After that I also like to do an smooth weight command. Tips on that are also welcome!
All help is appreciated!
Thanks!
On 15/10/2017 at 08:53, xxxxxxxx wrote:
As the name vertexMap is per vertex and not per polygon.
Anyway here is an exemple I made for set/read weight data in python https://gist.github.com/gr4ph0s/1bc0075ce733afb8b6678531a37f065b
On 15/10/2017 at 09:47, xxxxxxxx wrote:
Thanks for the example script!:) Still a question (No expert I have to admit)
How do I read in my selection tag to be the value of the weight map?
On 16/10/2017 at 02:28, xxxxxxxx wrote:
assuming you have a polygon selection stored in a SelectionTag, get the BaseSelect from the SelectionTag (GetBaseSelect()). This BaseSelect stores the selection state per index (of points, polygons,...), see for example IsSelected().
In case the selection is not stored in a SelectionTag, but is only an active selection on a PolygonObject, then you can get the BaseSelect via GetPolygonS().
Now, as gr4ph0s already pointed out, when having a polygon selection, you will need to find out the points/vertices belonging to a selected polygon. Via PolygonObject.GetAllPolygons() (or GetPolygonR() or directly via GetPolygon()) you get the CPolygon structure of a polygon, which stores the point indeces you are looking for.
