Adding object to In/Exclusion List
  • On 05/10/2017 at 11:58, xxxxxxxx wrote:
    I'm trying to create a null and add it to an in/exclusion list. The list is in the user data of an xpresso tag. This will be run off of a script. I have this code so far:
    from c4d import gui, utils
    def main() :
        document = doc
        tagowner = doc.SearchObject('StageLightMaster')
        xtag = tagowner.GetFirstTag()
        LinkList = xtag[c4d.ID_USERDATA,1]
        NullMaster = c4d.BaseObject(5140)
        document.InsertObject(NullMaster)
        LinkList.InsertObject(NullMaster,1)
    if __name__=='__main__':
    I can run a count before and after the object is added and it seems to be running properly, but when I go to the list in the tag it is not updated to include the null. I read somewhere that I need to update the gui object for the changes to take place, but I'm not sure how to call it. Any help is greatly appreciated! Thanks!
  • On 06/10/2017 at 02:05, xxxxxxxx wrote:
    Add
    xtag[c4d.ID_USERDATA,1] = LinkList
    Before your EventaAdd().
    If we go step by step in your program here is what happend.
    mport c4d
    def main() :
        #Get the obj
        document = doc
        #Get the tag
        #Get a copy in memory of xtag[c4d.ID_USERDATA,1]
        #Create in memory a new object an copy it to NullMaster
        #Insert The the object into the document
        #Insert the object into your linklist variable which is a copy in memory of the userdata
        #Trigger an event
    So as you see you only change value on memory so you need to push back into the object ;)
    Hi and Welcome to the Plugin Cafe forums!
    LinkList in your script (retrieved with xtag[c4d.ID_USERDATA,1]) is a copy of the actual in/exclusion user data.
    So it has to be assigned to xtag[c4d.ID_USERDATA,1], after inserting the null object, for the in/exclusion user data to be updated in the GUI.
  • On 06/10/2017 at 05:40, xxxxxxxx wrote:
    Well you guys are just awesome! Thanks for explaining the logic behind the solution this helps me out tremendously.
