On 03/10/2017 at 00:51, xxxxxxxx wrote:
User Information: Cinema 4D Version: R17 Platform: Windows ; Language(s) : C++ ;
--------- Hello.
I press right-click in a TreeViewCustomGUI and a menu appears with "Remove" and "Remove all" options. The TreeViewFunctions callback ContextMenuCall is called only when I click the second options (900001). It is not triggered when I click the first option.
Thank you.
On 03/10/2017 at 02:09, xxxxxxxx wrote:
How do you build your menu?
On 03/10/2017 at 02:28, xxxxxxxx wrote:
Hello.
I don't build the menu. It's already there as default I suppose. You can check the Active Object Dialog SDK example. If you right-click the treeview, you'll see the default menu "Remove" and "Remove All".
The problem is that ContextMenuCall is not called when I click Remove. It's id is FIRST_POPUP_ID. I don't need it. I just report a possible bug.
On 03/10/2017 at 08:06, xxxxxxxx wrote:
Hi Peterakos, thanks for writing us.
After investigating, I confirm that the behavior associated to FIRST_POPUP_ID id, when used for context menus in TreeViewCustomGui, is hard-coded in Cinema API resulting in no chance to execute custom code.
That said, it's worthy noting that this can't be considered a bug since the documentation referring to creating context menus (TreeViewFunctions::CreateContextMenu()) warnings to start the first menu id should be at least equal to ID_TREEVIEW_FIRST_NEW_ID.
Best, Riccardo.
