Check if Object is deformer
On 29/09/2017 at 06:30, xxxxxxxx wrote:
Hello, is it possible to check if an Object is a Deformer?
I can check if an object is a Generator like this:obj_info = obj.GetInfo()
is_generator = obj_info & c4d.OBJECT_GENERATORBut trying this with c4d.OBJECT_DEFORMER
seems not to work.
On 29/09/2017 at 07:16, xxxxxxxx wrote:
c4d.OBJECT_MODIFIER and c4d.OBJECT_HIERARCHYMODIFIER is what you need
On 02/10/2017 at 01:22, xxxxxxxx wrote:
Hi holgar, thanks for writing us.
With reference to your request, beside what gr4ph0s already stated, I warmly invite you to have a look to the flags used to describe the type and behavior an BaseObject is supposed to deliver.
Best, Riccardo.
On 02/10/2017 at 01:43, xxxxxxxx wrote:
Thank you a lot. That helped me.
