On 03/09/2017 at 04:53, xxxxxxxx wrote:
Is it possible to control timeline's play/pause via Python or Xpresso in someway?
On 03/09/2017 at 05:22, xxxxxxxx wrote:
Using the Console log
c4d.CallCommand(12412) # Play Forwards
But the problem with that is you don't have a lot of control about it. So I propose you to use this method instead which allow you to customize how you want to play the animation.
import c4d def main() : fps = doc.GetFps() frame = 0 #Starting frame maxFrame = doc.GetLoopMaxTime().GetFrame(fps) #end frame #Loop until our frame number is egual to our max frame while frame < maxFrame: #We change the time doc.SetTime(c4d.BaseTime(frame, fps)) #We redraw everything c4d.DrawViews(c4d.DRAWFLAGS_FORCEFULLREDRAW) #Send message to tell c4d the time changed c4d.GeSyncMessage(c4d.EVMSG_TIMECHANGED) #Do something here... c4d.CallCommand(12410) # Record Active Objects #we define our next frame frame += 1 #Update the whole scene c4d.EventAdd() if __name__=='__main__': main()
On 04/09/2017 at 02:46, xxxxxxxx wrote:
there's also RunAnimation(), which works quite nicely.
