On 25/08/2017 at 20:36, xxxxxxxx wrote:
User Information: Cinema 4D Version: R18 Platform: Windows ; Mac OSX ; Language(s) : C++ ;
--------- I want to change the display of the parameter of CKey, but I can not do it. Although it is possible to switch display with GetDDescription, KeyGetDDescription can not automatically switch, it can not switch without manipulating other elements or once you have selected another one. Please tell me if anyone knows.
Bool BlinkerTrack::KeyGetDDescription(CTrack* track, CKey* node, Description* description, DESCFLAGS_DESC& flags) { if (!(flags & DESCFLAGS_DESC_LOADED)) { if (description->LoadDescription(auto_id)) flags |= DESCFLAGS_DESC_LOADED; CKey* key = node; GeData ds; key->GetParameter(DescLevel(ID_AAA), ds, DESCFLAGS_GET_0); if(ds.GetInt32() == CH_BBB) { BaseContainer *bc1 = description->GetParameterI(DescLevel(ID_DDD), NULL); if (bc1) bc1->SetBool(DESC_HIDE, true); } else { BaseContainer *bc1 = description->GetParameterI(DescLevel(ID_DDD), NULL); if (bc1) bc1->SetBool(DESC_HIDE, false); } } return flags & DESCFLAGS_DESC_LOADED; }
Edit: Fixed code tags
On 29/08/2017 at 09:05, xxxxxxxx wrote:
I can reproduce your issue. I'm currently waiting for feedback from development.
On 30/08/2017 at 10:28, xxxxxxxx wrote:
no really good news for you. The only workaround I can offer is to use KeyGetDEnabling(), so instead of hiding just disabling the parameters. There the updating works correctly. I have filed a bugreport for our development on the KeyGetDDescription() issue.
On 01/09/2017 at 08:00, xxxxxxxx wrote:
Thank you for checking. I will respond by the method taught. I hope that KeyGetDDescription () will be modified.
