On 16/02/2003 at 09:17, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.012 Platform: Windows ; Language(s) : C++ ;
--------- I add BitmapButtons to my ObjectPlugin (as in morphmixer example). I am using a bitmapbutton in another objectplugin already (like the example Mikael once posted here in the forum), this works fine, no problems. But when I add bitmapbuttons I never get a message of type MSG_DESCRIPTION_GETBITMAP, so there is no picture in the button. Here is some code of my plugin:
Bool TreelibData::GetDParameter(GeListNode* node, const DescID& id, GeData& t_data, LONG& flags) { BaseContainer *vdata = ((BaseObject* )node)->GetDataInstance(); for(LONG i=0;i<vdata->GetLong(TREEGEN_IDC)+1;i+=2) { if(id[0].id==i) { PluginMaterial *mat = (PluginMaterial* )node; LONG dirty = 0; BitmapButtonStruct bbs(static_cast<PluginObject*>(node), DescID(i), dirty); t_data = GeData(CUSTOMDATATYPE_BITMAPBUTTON,bbs); //bbs overwritten... flags |= DESCFLAGS_PARAM_GET; } } return ObjectData::GetDParameter(node, id, t_data, flags); } Bool TreelibData::GetDDescription(GeListNode *node, Description *description,LONG &flags) { if (!description || !node) return FALSE; if (!description->LoadDescription(node->GetType())) return FALSE; [...] ++i; BaseContainer bc2 = GetCustomDataTypeDefault(DTYPE_BUTTON); bc2.SetLong(DESC_CUSTOMGUI,CUSTOMGUI_BITMAPBUTTON); bc2.SetBool(BITMAPBUTTON_BUTTON,TRUE); bc2.SetLong(BITMAPBUTTON_BORDER,1); if (!description->SetParameter(DescLevel(i),bc2,DescLevel(TREEGEN_LIBRARY))) return FALSE; } } data->SetLong(TREEGEN_IDC,i); } flags |= DESCFLAGS_PARAM_SET; return ObjectData::GetDDescription(node, description, flags); } Bool TreelibData::SetDParameter(GeListNode* node, const DescID& id, const GeData& t_data, LONG& flags) { BaseContainer *data = ((BaseObject* )node)->GetDataInstance(); for(LONG i=0;i<data->GetLong(TREEGEN_IDC)+1;i+=2) { if(id[0].id==i) { flags |= DESCFLAGS_PARAM_SET; } } return ObjectData::SetDParameter(node, id, t_data, flags); } [...] if (type == MSG_DESCRIPTION_GETBITMAP) { GePrint("message"); }
There are two bitmapbuttons I am testing it with. Variable i represents the bitmapbuttons ID. So the buttons have the id 2 and 4. But as I said I never get a message. What´s wrong? Thanks Samir
On 16/02/2003 at 09:21, xxxxxxxx wrote:
And yes, the ids are correct, are called correctly etc. Already checked. There seems to be an error (surely my fault) that I cannot find... :\
On 16/02/2003 at 09:45, xxxxxxxx wrote:
ok, forget about it. Got it. It was the ids. *shame* :)
