On 16/08/2017 at 23:26, xxxxxxxx wrote:
Ciao! I would like to develop a dialog windows with some EditText precompilated automatically when other EditText is compilated. For example:
Dialog windows with 2 EditText:
When user insert a Rise Height value, automatically in Thread field appear a value (that user can modify).
Thanks!!
On 16/08/2017 at 23:48, xxxxxxxx wrote:
You may want to use the Command() function of class GeDialog. https://developers.maxon.net/docs/Cinema4DPythonSDK/html/modules/c4d.gui/GeDialog/index.html#c4d.gui.GeDialog
On 17/08/2017 at 02:28, xxxxxxxx wrote:
mp5gosu already provided a good hint, in Command() you are free to set dependencies between different data or widgets, i.E. changing b as well, when user interacted with a.
Maybe you also want to take a look at the GeDialog manual in our C++ documentation.
But the more important question for me is, it seems as if you are using a string input (EditText) in order to get numerical values? Is there a specific reason (please forgive, I didn't take a look at the plugin, yet) to do so? Wouldn't a numerical input (AddEditNumber(), AddEditNumberArrows()) or slider (AddSlider(), AddEditSlider()) be the more logical choice?
On 17/08/2017 at 07:09, xxxxxxxx wrote:
Thanks guys! ...and yes, Andreas..you are right! I have used string input by mistake (with 4 useless lines of code for manage input format ...I need vacation!)
This is the new version (Beta 0.85) of SCALAX plugin with your tips. https://www.dropbox.com/s/53q0o0bgdz6ex95/ScalaX_v085.zip?dl=0
