On 15/08/2017 at 06:36, xxxxxxxx wrote:
Hi everyone! I want share with you my first job in Python. It's a beta version free...so please let me know any errors or suggestions about it. Plugin allows to create automatically a staircase, opened 2 sides, with the following parametres: - Number of steps - Thread and rise thickness - Thread depth - Rise height - Stairs nosing - Width - Slab thickness
https://www.dropbox.com/s/4tx4la7zgx5sacn/ScalaX_v07.zip?dl=0 Read instructions in the zip file for more informations. Thanks!
Riccardo
On 15/08/2017 at 06:58, xxxxxxxx wrote:
There seems to be a bug in it. Tread Depth is always set to one when using comma instead of point. And the lower normal of the slab is inverted. But good work so far.
By the way, you should add an auto tread-depth since they are almost always normed. Plus: Make it realtime.
I attached an old, simple stair generator, maybe you can use some portions of the code.
P.S.: Sorry for not commenting the code, but it was a quick no-brainer that we needed at work.
https://drive.google.com/file/d/0Bx7BVbhuezc_WDJZLUY5bU1tTUE/view?usp=sharing
On 16/08/2017 at 06:53, xxxxxxxx wrote:
Thanks for reply! I'm going to implement your suggestions
On 16/08/2017 at 23:17, xxxxxxxx wrote:
New release with correction of some bugs found by mp5gosu .
https://www.dropbox.com/s/vygjk4g7939utp0/ScalaX_v08.zip?dl=0
On 20/08/2017 at 00:20, xxxxxxxx wrote:
New release (Beta v.085) with implementation of Blondel formula, as suggested by mp5gosu https://www.dropbox.com/s/53q0o0bgdz6ex95/ScalaX_v085.zip?dl=0
