On 10/08/2017 at 09:41, xxxxxxxx wrote:
I'm confused from the documentation:
How do you get/set the pixel value of a GRAYSCALE image (i.e. one created with a color mode of c4d.COLORBYTES_GRAYf).
bitmap.GetPixel(x,y) returns a tuple of R, G, B, not a float bitmap.SetPixel(x,y,r,g,b) doesn't allow for providing a float
Are there float versions of Get/SetPixel?
On 10/08/2017 at 10:22, xxxxxxxx wrote:
A grayscale is basicly a vector with the 3 same component.
You can decompose a color where each component can be understand as a value from 0 to 255 (where 0 red is no red and 255 red is full red for exemple) so if you want to convert them in color space of c4d (c4d oftenly use vector from 0 for no color and 1 for the full color) so with those functions you can have everything you need
import c4d def rgb_to_vector(data) : rgbv = c4d.Vector(data[0], data[1], data[2]) return rgbv ^ c4d.Vector(1.0 / 255.0) def vector_to_rgb(vector) : return vector ^ c4d.Vector(255.0) def main() : vector = rgb_to_vector(bmp.GetPixel(0,0)) print vector rgb = vector_to_rgb(vector) print rgb if __name__=='__main__': main()
Hope it make more sense
On 10/08/2017 at 12:27, xxxxxxxx wrote:
So, I guess what you're basically saying is that r, g, b for Set and GetPixel will accept/return floats :). Problem is: The documentation clearly states that the three color components are INT with values from 0-255 (so basically a BYTE type). Assuming all of these are the same for gray values, you would basically end up with a maximum number of 256 gray values. This is obviously NOT correct...
On 10/08/2017 at 12:48, xxxxxxxx wrote:
Originally posted by xxxxxxxx So, I guess what you're basically saying is that r, g, b for Set and GetPixel will accept/return floats :).
I never told that but I agree I should be more clear.
I provided you functions to convert vector returned from 99% of color returned by c4d. Wich are normalized vector. But GetPixel/SetPixel didn't fit this rules. They return raw RGB data wich are as you said 3 INT with a range from 0 to 255 and where thoses 3 INT correspond in the respectif order to the Red channel, green one and blue one.
This method (to use 0/255 range for each channel) is oftently used for describe color. And yes you only get 256gray value and that end's up with a 8bit picture. If you want to deal with more than 8bit picture I suggest you to read https://github.com/PluginCafe/cinema4d_py_sdk/blob/master/scripts/Copy32BitImage.py wich basicly use SetPixelCnt for setting pixel.
On 10/08/2017 at 12:58, xxxxxxxx wrote:
Ah, thx! Good pointer with the SetPixelCnt. I'll give it a shot.
On 11/08/2017 at 08:08, xxxxxxxx wrote:
the C++ docs have a manual about BaseBitmap, maybe the code snippet on Pixel Data might help future readers of this thread.
