Using char key modifiers
On 04/08/2017 at 19:34, xxxxxxxx wrote:
I made a simple script to help easily rotate an object by 90 degrees, the axis is determined by a predefined key ("1", "2", "3") being held prior to script execution.
This seems to work well, I tried it with the script mapped to the ` key.
I wanted to check if it is written in the best way, especially considering where I have put my undo steps:
from c4d import gui
def checkPressed(k) :
    # Check any one key
    bc = c4d.BaseContainer()
    if c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD, k ,bc) :
        if bc[c4d.BFM_INPUT_VALUE] == 1:
            print "%s PRESSED" % unichr(k)
            print "%s NOT PRESSED" % unichr(k)
            return False
def rotat(obj, r) :
    doc.StartUndo()
    doc.AddUndo(c4d.UNDOTYPE_HIERARCHY_PSR, obj)
    if r is "x":
        newMatrix = obj.GetMl() * c4d.utils.MatrixRotX(c4d.utils.Rad(90))
    elif r is "y":
        newMatrix = obj.GetMl() * c4d.utils.MatrixRotY(c4d.utils.Rad(90))
    elif r is "z":
        newMatrix = obj.GetMl() * c4d.utils.MatrixRotZ(c4d.utils.Rad(90))
        print "error"
    obj.SetMl(newMatrix)
    doc.EndUndo()
def main() :
  obj=doc.GetActiveObject()
  if obj is None:
        pass
  if checkPressed(ord('1')) :
    rotat(obj, "x")
  elif checkPressed(ord('2')) :
    rotat(obj, "y")
  elif checkPressed(ord('3')) :
    rotat(obj, "z")
if __name__=='__main__':
On 05/08/2017 at 05:57, xxxxxxxx wrote:
Update (https://github.com/NNNenov/C4Dhandy/blob/master/scripts/functional/Turn90/Turn90.py )
    # Check any one key
            return False
def rotat(obj, r) :
    doc.StartUndo()
    if r is "x":
        newMatrix *= c4d.utils.MatrixRotX(c4d.utils.Rad(90))
    elif r is "y":
        newMatrix *= c4d.utils.MatrixRotY(c4d.utils.Rad(90))
    elif r is "z":
        newMatrix *= c4d.utils.MatrixRotZ(c4d.utils.Rad(90))
    doc.EndUndo()
def main() :
  #obj = doc.GetActiveObject()
  objs = doc.GetActiveObjects(0)
  if len(objs) == 0:
        pass
  for obj in objs:
        rotat(obj, "x")
        rotat(obj, "y")
        rotat(obj, "z")
On 07/08/2017 at 02:58, xxxxxxxx wrote:
I see no problem with the position of the undo step.
In regards to "best way", I leave any discussion on optimization up to the community.
