Overriding An Objects BaseDraw
On 28/07/2017 at 15:22, xxxxxxxx wrote:
Cinema 4D Version: 14
Platform: Mac ;
Hi,Is there a way to prevent an object's BaseDraw output from showing up in the viewport? Similar to a Display Tag. I want to put a tag plugin on a Spot Light and stop it from drawing in the viewport and instead use the Tag's BaseDraw to output something different.
Dan
On 31/07/2017 at 02:59, xxxxxxxx wrote:
Hi Dan,
unfortunately there's no direct or official way to achieve this.
We discussed a possible solution, which is probably not ideal and also shouldn't be considered as an official approach, but you may want to consider it anyway.
You could use MSG_MENUPREPARE to create an additional Display tag. Setting the "Style" parameter in the Display tag to "Skeleton" would reduce the light to be drawn just as a point.
Also you may run into issues using Draw() in your TagData directly. Instead doing the drawing in a SceneHook as described in this blog article could help then.
