commandline automation
  • On 20/07/2017 at 12:25, xxxxxxxx wrote:
    I am trying to get a plugin to run via commandline that we are developing.
    but I am getting errors complaining about "Missing serial number for 'CINEMA 4D'"
    Running c4d normally works as expected.
    Do I need a special license to run commanline tool  ?
    Thanks Roger
    Invalid License from License Server
    Missing serial number for 'CINEMA 4D'!
    "D:/MAXON/CINEMA 4D R17/Commandline.exe" -licence ourlicenseserverip 5235
    Application start      : 07/20/17 at 12:18:24
    Executable             : 64 Bit
    Version / Build        : 17.048 / RB147424
    Debugger               : not available
    Memory model           : release
    Startup path           : file:///D:/MAXON/CINEMA 4D R17
    Application path       : file:///D:/MAXON/CINEMA 4D R17/Commandline.exe
    Application executable : file:///D:/MAXON/CINEMA 4D R17/Commandline.exe
    Resource path          : file:///D:/MAXON/CINEMA 4D R17/resource
    Module path(s)         : file:///D:/MAXON/CINEMA 4D R17/modules
    Temporary path         : file:///C:/Users/roger/AppData/Local/Temp
    Prefs path             : file:///C:/Users/roger/AppData/Roaming/MAXON/CINEMA 4D R17_B41BFFA7
    Global Prefs path      : file:///C:/Users/roger/AppData/Roaming/MAXON
    OS version             : Windows 10, 64 Bit, Professional Edition (build 15063)
    Processor              : 4(8)x Intel Core i7-6700K CPU
    Computer name          : I7-6700
    Thread Count           : 8
    Cpu Speed (MHz)        : 4010.000
    Application Type       : Modular
    Command line arguments : "-licence" ourlicenseserverip "5235"
    Loading file:///D:/MAXON/CINEMA 4D R17/modules/c4dplugin.xdl64 with module(s) net.maxon.c4d.c4dplugin
    Loading file:///D:/MAXON/CINEMA 4D R17/modules/crashhandler.module.xdl64 with module(s) net.maxon.crashhandler
    Loading file:///D:/MAXON/CINEMA 4D R17/modules/crypt.module.xdl64 with module(s) net.maxon.crypt
    Loading file:///D:/MAXON/CINEMA 4D R17/modules/image.module.xdl64 with module(s) net.maxon.image
    Loading file:///D:/MAXON/CINEMA 4D R17/modules/mesh.module.xdl64 with module(s) net.maxon.mesh
    Loading file:///D:/MAXON/CINEMA 4D R17/modules/misc.module.xdl64 with module(s) net.maxon.misc
    Loading file:///D:/MAXON/CINEMA 4D R17/modules/network.module.xdl64 with module(s) net.maxon.network
    Loading file:///D:/MAXON/CINEMA 4D R17/modules/triangulation.module.xdl64 with module(s) net.maxon.triangulation
  • On 21/07/2017 at 07:39, xxxxxxxx wrote:
    welcome to the Plugin Café forums 🙂
    Yes, the commandline renderer needs special serial number, that can be bought separately.
    But if it helps, you can start the normal Cinema 4D executable from commandline providing additional options and switches.
