Arrange UI Elements
On 19/07/2017 at 08:15, xxxxxxxx wrote:
I'm quite new to python for c4d, so it might be newbie question.
Does anyone know how to organize elements so that they are arragend next to each other instead of top/down?
this is my current class
class MainMenu(gui.GeDialog) : def CreateLayout(self) : template_fn = next(os.walk(path))[2] template_filecnt = len(template_fn) #print template_fn #print template_filecnt bc = c4d.BaseContainer() #Create a new container to store the button image buttid = 1000 #start id for 1000 i=0 #set iterator for list in template_fn: #create buttons template_path = os.path.normpath(os.path.join(dir,'res/templates/',template_fn[i])) #The path to the image bc.SetFilename(buttid, template_path) #Add this location info to the conatiner self.myBitButton=self.AddCustomGui(buttid, c4d.CUSTOMGUI_BITMAPBUTTON, "Bitmap Button", c4d.BFH_CENTER, 30, 30, bc) self.myBitButton.SetImage(template_path, False) #Add the image to the button #button id counter, gives every button unique id, i = loop counter for iteration through list buttid+=1 i+=1 return True def Command(self, id, msg=None) : print id return True
On 19/07/2017 at 08:56, xxxxxxxx wrote:
I suggest you to read https://developers.maxon.net/docs/Cinema4DCPPSDK/html/page_manual_gedialog.html you gonna learn alot about dialog inside c4d.
According your ask take basicly you have to make a group to arrange them.
So it's looks like this
import c4d class MainMenu(c4d.gui.GeDialog) : def CreateLayout(self) : count = 10 id_group = 10001 base_id_text = 10002 #important to set columns number if self.GroupBegin(id_group, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, cols=count) : #Add content to our group for i in xrange(count) : self.AddStaticText(base_id_text + i, c4d.BFH_SCALEFIT, name="text_{}".format(str(i))) self.GroupEnd() return True def main() : win = MainMenu() win.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE) if __name__=='__main__': main()
On 20/07/2017 at 00:28, xxxxxxxx wrote:
Thanks, it works like a charm!
and thanks for the cpp manual link it gives lots more info then the python one.
