On 29/06/2017 at 08:59, xxxxxxxx wrote:
I have 2 different C4D_PLUGINS_DIR paths for plugins.
Both of them work well independantly (if using only 1 path at the time). When I declare both using environment variable 'C4D_PLUGINS_DIR', none of them work anymore (No plugin loaded). I made sure not 2 plugins ID where the same.
EX: C4D_PLUGINS_DIR = D:\pathAAA\plugins;C:\pathBBB\plugins
I found that post, but doesn't quite understand what is needed... https://www.c4dcafe.com/ipb/forums/topic/97568-c4d-environment-variables/
Jonathan
On 30/06/2017 at 01:50, xxxxxxxx wrote:
Hi Jonathan,
unfortunately there's a known bug in R18, which breaks the ability to have multiple directories in the C4D_PLUGINS_DIR environment variable. Terribly sorry.
