Fill ShaderData preview
On 15/06/2017 at 02:54, xxxxxxxx wrote:
Cinema 4D Version:   R18
Platform:   Windows  ;
Hello.
I have a ShaderData plugin that I need to set value to its preview.
I know I Have to use InitRender and FreeRender to setup and destroy my data.
The problem is that Output method feels a little bit slow since I have to set the value for each UV separately. Also, I use an external lib to calculate the shader that can be done in the InitRender.
Can I avoid Output and simply set the shader preview by copying the base bitmap ? Is there any message to which I have to respond to achieve that ?
Thank you very much for your time.
On 16/06/2017 at 02:20, xxxxxxxx wrote:
no, this is not possible. You can of course create the bitmap in InitRender() and then only sample (basically copy pixels) the bitmap in Output().
On 16/06/2017 at 05:16, xxxxxxxx wrote:
Thank you very much Andreas.
