On 18/05/2017 at 03:19, xxxxxxxx wrote:
On 18/05/2017 at 03:26, xxxxxxxx wrote:
VS 2017 is not supported. https://developers.maxon.net/?page_id=1108
And about VS 2015 https://plugincafe.maxon.net/topic/9606/12903_vs-2015-update-3-compiler-changes
On 18/05/2017 at 03:29, xxxxxxxx wrote:
Thank you for the quick reply
On 18/05/2017 at 05:36, xxxxxxxx wrote:
On 18/05/2017 at 07:08, xxxxxxxx wrote:
If you look at this page: https://developers.maxon.net/?page_id=1108
You'll see that VS 2013, not VS 2012, is required for R18. If you have VS 2012, you can develop for R16 and you may well find that your plugin will also run in R17 and R18, but it may not.
If necessary you can still get the VS 2013 community edition which is free and will do all you need for plugin development.
Steve
On 18/05/2017 at 07:36, xxxxxxxx wrote:
On 19/05/2017 at 02:37, xxxxxxxx wrote:
On 19/05/2017 at 02:47, xxxxxxxx wrote:
No there is two main repository one for python and one for C++.
I really suggest you to take a look at those videos https://www.youtube.com/watch?v=tN_CtBER9Xc (you can followin it with VS 2013 and R18) There is no real change. And the part two https://www.youtube.com/watch?v=3CI_PsMcgFE&t=1720s
You also get this one: https://vimeo.com/76450595
But what I do on each new release. I copy the sdk exemple in my HDD. I copy the sdk_exemple into another folder within the plugin forlder of c4d. I open the solution according the right VS version. I remove every files who are into the sdkExemple(don't touch to cinema.framework) And that's it you can start.
On 19/05/2017 at 02:51, xxxxxxxx wrote:
Thanks for your support
On 19/05/2017 at 03:07, xxxxxxxx wrote:
Hi Lawrence,
welcome to the Plugin Café forums
On your question in your first post:
Unable to start program \ Program Files \ MAXON \ CINEMA 4D R18 \ plugins \ cinema4dsdk \ ProjectName.cdl64
In the end a plugin is a library (dll), this can't be started directly. Instead you need to tell VisualStudio to call the Cinema 4D application, when you want to debug your plugin. See this page on Debugging Plugins, the screenshot in chapter 1.1.1 shows how to set this up.
And then I'd say, before setting up your own project you probably want to try to compile the example plugins (the cinema4dsdk.sln). If you run into any problems with this, don't hesitate to get back here. In this case try to provide as much details as possible, especially any messages in VisualStudio's console or output window can be helpful.
On 19/05/2017 at 03:11, xxxxxxxx wrote:
On 19/05/2017 at 04:07, xxxxxxxx wrote:
On 22/05/2017 at 08:39, xxxxxxxx wrote:
Hi Lorenzo, let's try to find a solution to this lengthy discussion, but first of all a few notes about posting in this forum:
With reference to the issue reported, please consider the following compatibility table: Cinema 16 - Visual Studio 2012 Cinema 17 /18 - Visual Studio 2013
First of all let's check that the development environment is properly configured.
If all the steps below have been successfully accomplished, you can be sure that your development environment is working properly.
Now you can get rid of all the files contained in your MyFirstPluginProject, by selecting them from the Solution Explorer in VS2013 and deleting them. Simply select them all, right click and select " Remove ". At this stage you can add your own files and start having fun developing with Cinema 4D.
Hoping this short set of steps could lead you to get rid of all your issue, I warmly invite posting into this thread any further issue.
Best, Riccardo.
On 22/05/2017 at 10:28, xxxxxxxx wrote:
Thank you so much! Riccardo, I am solving ... If I'll have any problems, I'll let you know through the forum.
On 22/05/2017 at 15:18, xxxxxxxx wrote:
I have problems with the code ..
I've already created the dialog with ResEdit and, I have correctly configured the description files and the c4d_symbols.h file. But I get these bugs on the code ...
IDE | VISUAL STUDIO VS2013 For Plug-in Cinema 4D R18
MyPlugin.cpp
#include "c4d.h" #include "c4d_symbols.h" #include "MyPlugin.h" #define PLUGIN_TEMPLATE_ID 1039315 /***********************************************/ /* Plugin Template */ /***********************************************/ PluginTemplate::PluginTemplate() { } PluginTemplate::~PluginTemplate(void) { } Bool PluginTemplate::CreateLayout(void) { if (!GeDialog::CreateLayout())return FALSE; if (!LoadDialogResource(PLUGIN_TEMPLATE_ID, NULL, 0))return FALSE; return TRUE; } Bool PluginTemplate::InitValues(void) { if (!GeDialog::InitValues())return FALSE; this->SetReal(IDC_EDIT1, 200.0, 1, 1000, 10); this->SetReal(IDC_EDIT2, 200.0, 1, 1000, 10); this->SetReal(IDC_EDIT3, 200.0, 1, 1000, 10); return TRUE; } Bool PluginTemplate::Command(Int32 id, const BaseContainer &msg) { Real edit1 this->GetReal(IDC_EDIT1, edit1); Real edit2 this->GetReal(IDC_EDIT2, edit2); Real edit3 this->GetReal(IDC_EDIT3, edit3); return TRUE; } /***********************************************/ /* Template */ /***********************************************/ class PluginTemplateCommand : public CommandData { public: /* Constructor & Descriptor */ PluginTemplateCommand(); virtual ~PluginTemplateCommand(); virtual Bool Execute(BaseDocument *doc); virtual Bool RestoreLayout(void *secret); private: PluginTemplate *dlg; }; PluginTemplateCommand::PluginTemplateCommand() { dlg = NULL; } PluginTemplateCommand::~PluginTemplateCommand() { gDelete(dlg); } Bool PluginTemplateCommand::Execute(BaseDocument* doc) { if (!dlg) dlg = gNew PluginTemplate; if (!dlg) return FALSE; dlg->Open(DLG_TYPE_ASYNC, PLUGIN_TEMPLATE_ID); return TRUE; } Bool PluginTemplateCommand::RestoreLayout(void* secret) { if (!dlg) dlg = gNew PluginTemplate; if (!dlg) return FALSE; dlg->RestoreLayout(PLUGIN_TEMPLATE_ID, 0, secret); return TRUE; } /***********************************************/ /* Register Plugin */ /***********************************************/ Bool RegisterPluginTemplate() { return RegisterCommandPlugin(PLUGIN_TEMPLATE_ID, "Plugin Template", 0, AutoBitmap("Icon.png"), String(), gNew PluginTemplateCommand); }
On 22/05/2017 at 15:21, xxxxxxxx wrote:
I have problems with, gDelete, gNew, SetReal Console Log Response ________
1 IntelliSense: class "PluginTemplate" has no member "SetReal" c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 32 8 PluginTemplate 2 IntelliSense: class "PluginTemplate" has no member "SetReal" c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 33 8 PluginTemplate 3 IntelliSense: class "PluginTemplate" has no member "SetReal" c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 34 8 PluginTemplate 4 IntelliSense: identifier "Real" is undefined c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 42 2 PluginTemplate 5 IntelliSense: expected a ';' c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 42 13 PluginTemplate 6 IntelliSense: identifier "Real" is undefined c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 43 2 PluginTemplate 7 IntelliSense: expected a ';' c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 43 13 PluginTemplate 8 IntelliSense: identifier "Real" is undefined c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 44 2 PluginTemplate 9 IntelliSense: expected a ';' c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 44 13 PluginTemplate 10 IntelliSense: identifier "gDelete" is undefined c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 75 2 PluginTemplate 11 IntelliSense: identifier "gNew" is undefined c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 81 18 PluginTemplate 12 IntelliSense: expected a ';' c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 81 23 PluginTemplate 13 IntelliSense: identifier "gNew" is undefined c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 93 18 PluginTemplate 14 IntelliSense: expected a ';' c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 93 23 PluginTemplate 15 IntelliSense: identifier "gNew" is undefined c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 108 107 PluginTemplate 16 IntelliSense: expected a ')' c:\Program Files\MAXON\CINEMA 4D R18\plugins\PluginTemplate\source\MyPlugin\MyPlugin.cpp 108 112 PluginTemplate
On 22/05/2017 at 15:23, xxxxxxxx wrote:
MyPlugin.h
#include "c4d_gui.h" ////////////////////////////////////////// class PluginTemplate : public GeDialog { public: PluginTemplate(); virtual ~PluginTemplate(); virtual Bool CreateLayout(void); virtual Bool InitValues(void); virtual Bool Command(Int32 id, const BaseContainer &msg); };
On 22/05/2017 at 15:24, xxxxxxxx wrote:
main.cpp
#include "c4d.h" #include <string.h> Bool RegisterPluginTemplate(); Bool PluginStart(void) { if (!RegisterPluginTemplate()) return FALSE; return true; } void PluginEnd(void) { } Bool PluginMessage(Int32 id, void* data) { if (!resource.Init()) return FALSE; if (!RegisterPluginTemplate()) return FALSE; return false; }
On 22/05/2017 at 15:38, xxxxxxxx wrote:
I started from the structure of your samples.. Here the Screen ..
https://www.dropbox.com/s/qwbnsq8695ezezz/2017-05-23.png?dl=0
Thanks in advance for any help you are able to provide.
On 22/05/2017 at 17:22, xxxxxxxx wrote:
c4d_symbols.h
enum { // Dialog definitions of IDD_PLUGIN_TEMPLATE start here IDD_PLUGIN_TEMPLATE, IDC_EDIT1, IDC_EDIT2, IDC_EDIT3, // Dialog definitions of IDD_PLUGIN_TEMPLATE end here // End of symbol definition _DUMMY_ELEMENT_ };
