ScrollGroupBegin: Just first element is shown
On 27/04/2017 at 02:42, xxxxxxxx wrote:
Hey all,
Id like to create a scroll group with multiple items.
class Dlg(gui.GeDialog) : def CreateLayout(self) : self.ScrollGroupBegin(200, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, c4d.SCROLLGROUP_HORIZ | c4d.SCROLLGROUP_VERT) self.AddCheckbox(201, c4d.BFH_SCALEFIT | c4d.BFV_TOP, initw=200, inith=0, name="AAAAAA") self.AddCheckbox(202, c4d.BFH_SCALEFIT, initw=200, inith=0, name="BBBBBB") self.AddCheckbox(203, c4d.BFH_SCALEFIT, initw=200, inith=0, name="CCCCCC") self.GroupEnd() return True class Name(plugins.CommandData) : dialog = None def Execute(self, doc) : if self.dialog is None: self.dialog = Dlg() return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=100, defaulth=100) def RestoreLayout(self, sec_ref) : if self.dialog is None: self.dialog = Dlg() return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref) if __name__ == "__main__": bmp = bitmaps.BaseBitmap() dir, f = os.path.split(__file__) fn = os.path.join(dir, "res", "icon.tif") bmp.InitWith(fn) plugins.RegisterCommandPlugin(id=PLUGIN_ID, str="Name", info=0, help="Name", dat=Name(), icon=bmp)
But there is just the first item shown in window.
What Im doing wrong?Greetings
rownn
On 27/04/2017 at 02:56, xxxxxxxx wrote:
You have to make another group inside it.
So like that the scroll group will affect all items present in this groupimport c4d class Dlg(c4d.gui.GeDialog) : def CreateLayout(self) : if self.ScrollGroupBegin(200, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, c4d.SCROLLGROUP_HORIZ | c4d.SCROLLGROUP_VERT) : if self.GroupBegin(201, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, initw=200, inith=100) : self.AddCheckbox(202, c4d.BFH_SCALEFIT | c4d.BFV_TOP, initw=200, inith=0, name="AAAAAA") self.AddCheckbox(203, c4d.BFH_SCALEFIT, initw=200, inith=0, name="BBBBBB") self.AddCheckbox(204, c4d.BFH_SCALEFIT, initw=200, inith=0, name="CCCCCC") self.GroupEnd() self.GroupEnd() return True def main() : dialog = Dlg() dialog.Open(dlgtype=c4d.DLG_TYPE_MODAL_RESIZEABLE) if __name__=='__main__': main()
On 28/04/2017 at 04:35, xxxxxxxx wrote:
One more thread down, gr4ph0s
Just want to add a few links to the C++ side of things for future readers, maybe useful for Python developers as well:
In GeDialog manual this peculiarity of ScrollGroups is explicitly mentioned (not telling this to say "you should have known before", really not).
In C++ SDK examples gedialog_gadgets.cpp also contains an example on how to use ScrollGroups.
