Button minimum size
On 19/04/2017 at 08:41, xxxxxxxx wrote:
Hello I would like to have 2 buttons on top of each other with a character in their.
And the group who contain thoses two button must be less than 14px height. I tried a group but that didn't work. Even without any char buttons can't be into 14px.Is there any workaround? Thanks in advance
import c4d class mainDialog(c4d.gui.GeDialog) : def CreateLayout(self) : if self.GroupBegin(1001, c4d.BFH_SCALEFIT, 2, 0 , "", 0) : #inith is not take in cosideration if self.GroupBegin(1002, c4d.BFH_SCALEFIT | c4d.BFV_TOP, 1, 2 , "", inith=10) : self.AddButton(1003, c4d.BFH_CENTER | c4d.BFV_CENTER, name="▲", inith=4) self.AddButton(1004, c4d.BFH_CENTER | c4d.BFV_CENTER, name="▼", inith=4) self.GroupEnd() self.AddStaticText(1005, c4d.BFH_CENTER | c4d.BFV_TOP, name="Normally should be aligned with both buttons") self.GroupEnd() return True def main() : main_dlg = mainDialog() main_dlg.Open(dlgtype=c4d.DLG_TYPE_MODAL, defaultw=300, defaulth=150, xpos=-1, ypos=-1) if __name__=='__main__': main()
On 20/04/2017 at 06:19, xxxxxxxx wrote:
I don't think, you will get a button to reduce below font size. Sorry. But couldn't you use a BitmapButtonCustomGui instead?
On 20/04/2017 at 07:06, xxxxxxxx wrote:
Ok thanks for confirming what I thinked about button size and font size ! :)
But I guess it should be written somewhere button can't be smaller than font size even if the button is empty. Or maybe there is a way for set the font size inside the button.And yes I could go to BitmapButtonCustomGui but since it's use more ressource than a simple character and a button, I prefered ask before.
