On 18/04/2017 at 01:17, xxxxxxxx wrote:
How can I import my classes? The documentation says that the class should be registered as a plug-in. And how do I call it in the function body? How to name a class? And in which file to store the class (py or pyp)?
On 18/04/2017 at 02:38, xxxxxxxx wrote:
It seems there's some confusion here. Plugin data classes are loaded and registered automatically by Cinema. Custom/user/utility classes can be defined in py files and imported inside other py or pyp files.
The best solution is to organize the imported files/modules in subfolder(s). You can find interesting threads on Stack Overflow. For instance: Python: import a file from a subdirectory
It is strongly advised to not mess up with sys.path or PYTHONPATH.
Be aware Python can't import pyp files.
EDIT: Updated Python: import a file from a subdirectory link
