Creating a NormalTag?
  • On 17/04/2017 at 10:24, xxxxxxxx wrote:
    Cinema 4D Version:   R13
    Platform:   Windows  ;
    I'm having trouble creating a proper NormalTag on my polygon objects.
    When I add the new tag. The object is filled with tiny little lines. It looks like OpenGL is freaking out or something.
    I think this is happening because I have not set the tag data. But I'm having trouble figuring out use the Set() function.
    Can someone please post a working example?
    Thanks,
  • On 18/04/2017 at 02:43, xxxxxxxx wrote:
    Hi Scott,
    please check out the NormalTag manual, I think it should contain everything you need.
  • On 18/04/2017 at 07:49, xxxxxxxx wrote:
    Thanks Andreas. That helped me out a lot.
    This is the code version I added to my notes:
    //This is how to create a new normals tag on a polygon object
      PolygonObject *pobj = (PolygonObject* )doc->GetActiveObject();
      if (!pobj || pobj->GetType() != Opolygon) return false;
      CPolygon *polys = pobj->GetPolygonW();
      LONG polyCount = pobj->GetPolygonCount();
      //Get the NormalTag on the object
      NormalTag *normalTag = static_cast<NormalTag*>(pobj->GetTag(Tnormal));
      //If the object doesn't already have a normals tag on it...we add a new tag
      //NOTE: At this point the object will look very bad...filled with tiny openGL lines!!
      if (!normalTag)
          normalTag = NormalTag::Alloc(pobj->GetPolygonCount());
          if(normalTag)
              pobj->InsertTag(normalTag);
              EventAdd();
      //To fix this uglyness
      //We need to get the normal vectors of the object and store them in the new NormalTag
      //First make sure there is a phong tag on the object
      if (!pobj->GetTag(Tphong)) pobj->MakeTag(Tphong);
      //Get and store the polygon vectors in the new NormalTag so it doesn't look ugly anymore
      NormalHandle handle = normalTag->GetDataAddressW();
      for (LONG i = 0; i < polyCount; ++i)
          const CPolygon polygon = polys[i];
          //Calculate the default face normals
          Vector normal = CalcFaceNormal(pobj->GetPointR(), polygon);
          NormalStruct normals;
          //Save the normals data in the NormalTag
          normals.a = normal;
          normals.b = normal;
          normals.c = normal;
          normals.d = normal;
          NormalTag::Set(handle, i, normals);
      pobj->Message(MSG_UPDATE);
