I need to convert Python C4D Script to Plug-In
On 15/04/2017 at 11:52, xxxxxxxx wrote:
Hi, everyone!
Recently I build a script that create one null with one layer assigned for the c4d and now I'm trying convert this in plugin. The script runs perfect in my script manager but I have some problems when I try to convert it in plug in.
You can view the plug in code here:
Code:import os
import sysimport c4d
from c4d import *Plugin IDs 1000001-1000010 are reserved for development
PLUGIN_ID = 1000001
class AddNull(c4d.plugins.CommandData) :
def \__init\_\_(self) : color_Layer=c4d.Vector(1,1,1) # Layer Color def add_divider(self,name, color) : root = doc.GetLayerObjectRoot() LayersList = root.GetChildren() names=[] layers=[] for l in LayersList: n=l.GetName() names.append(n) layers.append((n,l)) if not name in names: c4d.CallCommand(100004738) # New Layer LayersList = root.GetChildren() layer=LayersList[-1] layer.SetName(name) layer[c4d.ID_LAYER_COLOR] =color else: for n, l in layers: if n ==name: layer=l break Null = c4d.BaseObject(5140) Null[c4d.ID_BASELIST_NAME] = "Null_01" #Name of null Null[c4d.ID_LAYER_LINK] = layer Null[c4d.NULLOBJECT_DISPLAY] = 14 doc.InsertObject(Null) c4d.EventAdd() def Execute(self, doc) : dialog = None
if self.dialog is None:
self.dialog = add_divider("_Layer01_", color_Layer)self.add_divider("_Layer01_", color_Layer)
icon = c4d.bitmaps.BaseBitmap()
icon.InitWith(os.path.join(os.path.dirname(__file__), "res", "Icon.tif"))
c4d.plugins.RegisterCommandPlugin(PLUGIN_ID, "Add_Null", 0, icon, "Add_Null", AddNull())----------------
You can download the script and the plug in here:I've been seeing some examples and the python SDK but I don't understand where is the issue because I saw different codes structures in examples and work well. It's necessary the "execute" function? Are there other ways to execute the function?
What I'm doing wrong?
I hope you can help me and thanks in advance!.
Cheers.
On 17/04/2017 at 08:43, xxxxxxxx wrote:
Hi and Welcome to the Plugin Cafe!
I tried the plugin and there are several minor errors related to the implementation of the script's code inside the context of a class.
Here are the issues:
- Execute() must return a boolean value i.e. True or False
- add_divider() should be passed doc variable from Execute()
- add_divider() call in Execute() missing self prefix
- color_Layer variables missing self prefix
- self.dialog really really useful?
On 03/05/2017 at 11:40, xxxxxxxx wrote:
You may have figured this out already, but if not, here you go. I commented out your old stuff and then added corrected code. I want to expand on what @yannick mentioned with his issues he saw. You were not actually registering the plugin either. Hope this helps you figure out where you went wrong.
files: https://dl.dropboxusercontent.com/u/13668972/c4d/addlayer_for_cybor09.zip
here is the code, it's also in that zip file packaged as a plugin
import os import sys import c4d from c4d import * # Plugin IDs 1000001-1000010 are reserved for development PLUGIN_ID = 1000001 class AddNull(c4d.plugins.CommandData) : def __init__(self) : self.color_Layer=c4d.Vector(1,1,1) # Layer Color def add_divider(self, doc, name, color) : root = doc.GetLayerObjectRoot() LayersList = root.GetChildren() names=[] layers=[] for l in LayersList: n = l.GetName() names.append(n) layers.append((n,l)) if not name in names: # ***************** # don't use CallCommand # c4d.CallCommand(100004738) # New Layer # ***************** # make a new layer layer = c4d.documents.LayerObject() # ***************** # set the layer name layer.SetName(name) # ***************** # set the layers properties here if needed # layer_settings = {'solo': False, 'view': False, 'render': False, 'manager': False, 'locked': False, 'generators': False, 'deformers': False, 'expressions': False, 'animation': False} # layer.SetLayerData(doc, layer_settings) layer[c4d.ID_LAYER_COLOR] = color #insert the new layer as a child of the layer root layer.InsertUnder(root) else: for n, l in layers: if n == name: layer = l # user lower case for variables # you should avoid using the actual ID and use the object type instead # https://developers.maxon.net/docs/Cinema4DPythonSDK/html/types/objects.html # Null = c4d.BaseObject(5140) null = c4d.BaseObject(c4d.Onull) null[c4d.ID_BASELIST_NAME] = "Null_01" #Name of null null[c4d.ID_LAYER_LINK] = layer null[c4d.NULLOBJECT_DISPLAY] = 14 # insert the null object doc.InsertObject(null) c4d.EventAdd() return True def Execute(self, doc) : # you are not using a dialog so you do not need this; it's doing absolutely nothing. """ dialog = None if self.dialog is None: self.dialog = add_divider("_Layer01_", color_Layer) """ # you have to return a True or False result. This result will come from the add_divider function name = "_Layer01_" return self.add_divider(name=name, doc=doc, color=self.color_Layer) if __name__ == '__main__': bmp = bitmaps.BaseBitmap() dir, file = os.path.split(__file__) fn = os.path.join(dir, "res", "Icon.tif") bmp.InitWith(fn) # you were not actually registering the plugin # https://developers.maxon.net/docs/Cinema4DPythonSDK/html/modules/c4d.plugins/index.html?highlight=register#c4d.plugins.RegisterCommandPlugin result = plugins.RegisterCommandPlugin(PLUGIN_ID, "Add Null", 0, bmp, "adds a null to a new layer", AddNull())
On 23/05/2017 at 10:22, xxxxxxxx wrote:
Thanks a lot guys! Sorry for my delay to answer.
I'm starting to learn Python and I'm making a bunch of bugs yet. I'll learn a lot to how to do this correctly with your files @charlesR. I want to learn the correct structure for python classes and c4d plugins.
Thanks again, cheers!
