On 14/04/2017 at 19:51, xxxxxxxx wrote:
Correct me, please!
class Brakers() : """docstring for Brakers""" def __init__(self, nameCBD, nameCBI, nameCBC) : #self.nameParent = nameParent self.nameCBD = nameCBD self.nameCBI = nameCBI self.nameCBC = nameCBC
def CreateBrakerDisk(self) : # добавляем ноль объект braker disc nameCBD = c4d.BaseObject(5170) nameCBD.SetName('eM ' + str(nameCBD)) # braker disc doc.InsertObject(nameCBD)
def CreateBrakerInstance(self) : nameCBI = c4d.BaseObject(5126) nameCBI.SetName('eM ' + str(nameCBI)) doc.InsertObject(nameCBI, nameCBD)
def CreateBrakerConnector(self) : # добавляем ноль объект wheel connector nameCBC = c4d.BaseObject(180000011) nameCBC.SetName('eM ' + str(nameCBC)) doc.InsertObject(nameCBC)
def main() : brakers_1_1 = Brakers(brakers_1_1, brakers_inst_1_1, brakers_connect_1_1)
if __name__=='__main__': main() c4d.EventAdd()
Concol ERROR: Traceback (most recent call last) : File "'scriptmanager'", line 34, in <module> File "'scriptmanager'", line 30, in main UnboundLocalError: local variable 'brakers_1_1' referenced before assignment
On 14/04/2017 at 21:49, xxxxxxxx wrote:
I got it
class Brakers() : """docstring for Brakers""" def __init__(self) : pass
def CreateBrakerDisk(self) : self.nameCBD = c4d.BaseObject(5170) self.nameCBD.SetName('eM ' + str(self.nameCBD)) doc.InsertObject(self.nameCBD)
def CreateBrakerInstance(self) : self.nameCBI = c4d.BaseObject(5126) self.nameCBI.SetName('eM ' + str(self.nameCBI)) doc.InsertObject(self.nameCBI, self.nameCBD)
def CreateBrakerConnector(self) : self.nameCBC = c4d.BaseObject(180000011) self.nameCBC.SetName('eM ' + str(self.nameCBC)) doc.InsertObject(self.nameCBC)
def main() : brakers_1_1 = Brakers() brakers_1_1.CreateBrakerDisk() brakers_1_1.CreateBrakerInstance() brakers_1_1.CreateBrakerConnector()
But name of objects eM <c4d.BaseObject object called 'Connector/Connector' with ID 180000011 at 0x000000000F572110>
How rename it?
On 15/04/2017 at 03:10, xxxxxxxx wrote:
Hello for rename use SetName(). How I know it? Simply go to the sdk. As you can read it's a c4d.BaseObject. So look at BaseObject class into the sdk. https://developers.maxon.net/docs/Cinema4DPythonSDK/html/modules/c4d/C4DAtom/GeListNode/BaseList2D/BaseObject/index.html?highlight=baseobject
In inheritance you can see C4d.BaseList2D. Then click on it. (since baseobject inherit from BaseList2D a BaseObject have all the function BaseList2D got)
And here you got SetName / GetName.
Hope it's help you
On 18/04/2017 at 01:21, xxxxxxxx wrote:
Thank you! There is an easier way!
def __init__(self, name = None, instance = 0, insertobject = None) : self.name = name self.instance = instance self.insertobject = insertobject
