Constraint tag properties
On 05/04/2017 at 12:03, xxxxxxxx wrote:
Cinema 4D Version: 16
Platform: Windows ;
I want to create a Clamp Constraint Tag.
That works except setting the Clamp To parameter.
In python it is constraintTag[50004,1] = c4d.ID_CA_CONSTRAINT_TAG_CLAMP_TO_SURFACE
How do I do this in C++.
I guess I must use DescID, but I am not sure how?//add constraint tag to null constraintTag = null->MakeTag(1019364); //# Constraint Tag = 1019364 constraintTag->SetName("Constraint Tag"); res = constraintTag->SetParameter(ID_CA_CONSTRAINT_TAG_CLAMP, TRUE, DESCFLAGS_SET_0); res = constraintTag->SetParameter(50001, surfaceObject, DESCFLAGS_SET_0); //set target res = constraintTag->SetParameter(DescID(50004, 1), ID_CA_CONSTRAINT_TAG_CLAMP_TO_SURFACE, DESCFLAGS_SET_0); res = constraintTag->SetParameter(DescID(50004, 3), ID_CA_CONSTRAINT_TAG_AXIS_ZP, DESCFLAGS_SET_0); //set align = +z res = constraintTag->SetParameter(DescID(50004, 4), 2, DESCFLAGS_SET_0);
On 07/04/2017 at 06:11, xxxxxxxx wrote:
All help is appreciated!
I am stuck at the moment.-Pim
On 07/04/2017 at 06:56, xxxxxxxx wrote:
I don't have a c++ environnent atm.
But here a python code which work and where you could easily port it into C++import c4d def main() : tag = doc.GetActiveTag() #useless but c++ code style bc = c4d.BaseContainer() #Get the bc bc = tag.GetParameter(c4d.DescID(50004), c4d.DESCFLAGS_GET_0) #Change the value to 2 => Z+ #Not sure it's a long maybe Int32 Don't know but oyu get the idea bc.SetLong(3, c4d.ID_CA_CONSTRAINT_TAG_AXIS_ZP) #Reassign the bc tag.SetParameter(c4d.DescID(50004), bc, c4d.DESCFLAGS_SET_0) c4d.EventAdd() if __name__=='__main__': main()
After maybe there is a more efficiency method to do it. But I guess this one will work.
Hope it's help.
On 07/04/2017 at 09:12, xxxxxxxx wrote:
Hi Pim,
sorry for letting you wait. Unfortunately I'm not done with your case, yet, but I don't want to leave you without any answer before the weekend.
In general your code seems to be working here. The thing is, while running in debugger, it's internally running on a bunch of CriticalStop(), which I haven't found the reason for, yet. Neither a workaround. These critical stops might look to you as if C4D has crashed, while it actually has not and you can simply press "continue" in your debugger. So if I use your code in a CommandData and step over the CriticalStops then the outcome looks actually fine to me.
So, I'm wondering, what is your actual issue. Is it the critical stops? I will investigate more in this direction Monday. But maybe you are having different issues, I have overlooked so far. In that case, please provide me with some more details.
On 07/04/2017 at 09:18, xxxxxxxx wrote:
Hi Andreas,
I do not get a crash of some sort.
The parameter is just not set.I will gr4ph0s solution.
-Pim
On 07/04/2017 at 09:20, xxxxxxxx wrote:
Hm, that part seems to work nicely here. Maybe you are just lacking the EventAdd() in the end? Or other question I forgot to ask, in which context are you using the posted code? Is it in a CommandData or somewhere else?
On 07/04/2017 at 09:42, xxxxxxxx wrote:
Yes, I am using a commanddata.
And I was wrong, cinema indeed seems to crash but I can continue, but the parameters are not set.
And yes, I use an EventAdd() at the end.I will do some test.
On 07/04/2017 at 09:56, xxxxxxxx wrote:
Running outside the debugger does gives no crashes, but not all parameters are not set.
Tag name set.
Clamp is set.
Target is set.
ID_CA_CONSTRAINT_TAG_CLAMP_TO_SURFACE not set.
ID_CA_CONSTRAINT_TAG_AXIS_ZP not set.
Phong Normals not set.constraintTag->SetName("C4Dome RL"); res = constraintTag->SetParameter(ID_CA_CONSTRAINT_TAG_CLAMP, TRUE, DESCFLAGS_SET_0); res = constraintTag->SetParameter(50001, surfaceObject, DESCFLAGS_SET_0); //set target res = constraintTag->SetParameter(DescID(50004, 1), ID_CA_CONSTRAINT_TAG_CLAMP_TO_SURFACE, DESCFLAGS_SET_0); res = constraintTag->SetParameter(DescID(50004, 3), ID_CA_CONSTRAINT_TAG_AXIS_ZP, DESCFLAGS_SET_0); //set align = +z res = constraintTag->SetParameter(DescID(50004, 4), 2, DESCFLAGS_SET_0);
On 07/04/2017 at 10:14, xxxxxxxx wrote:
Hi gr4ph0s,
I cannot get your solution to work.
The compiler complains or cinema hangs (in de code below).//Get the bc BaseContainer* bc; GeData d; res = constraintTag->GetParameter(DescID(50004), d, DESCFLAGS_GET_0); bc = d.GetContainer(); bc->SetInt32(1, ID_CA_CONSTRAINT_TAG_CLAMP_TO_SURFACE); //Reassign the bc d.SetContainer(*bc); constraintTag->SetParameter(DescID(50004), d, DESCFLAGS_SET_0);
On 07/04/2017 at 11:37, xxxxxxxx wrote:
#include "c4d.h" #include "c4d_symbols.h" #include "tcaconstraint.h" #include "main.h" #define ID_SWITCH_CONSTRAINT_TOOL 10000010 class SwitchConstCommand : public CommandData { Bool Execute(BaseDocument* doc) { if (!doc) return false; BaseTag* tag = doc->GetActiveTag(); if (tag == nullptr) return false; if (tag->GetType() != 1019364) return false; BaseContainer* bc_tag = tag->GetDataInstance(); BaseContainer* bc_clamp = bc_tag->GetContainerInstance(50004); bc_clamp->SetInt32(3, ID_CA_CONSTRAINT_TAG_AXIS_ZP); EventAdd(); return true; } }; Bool RegisterSwitchConst() { return RegisterCommandPlugin(ID_SWITCH_CONSTRAINT_TOOL, nullptr, 0, nullptr, String(), NewObjClear(SwitchConstCommand)); }
Worked here. But I just start to learn C++ and the c++ sdk so they might have a better solution for doing this kind of stuff using directly SetParameter.
On 07/04/2017 at 12:49, xxxxxxxx wrote:
Thanks, it works.
I forgot to get the first container.-Pim
